#221
Man thats looking killer!!! One of the best ive seen!! Keep up the awesome work!
#222
Yes, those are M5
ID is 18 mm.
#223
That's a really super job you've done on this model. It's almost a shame to put it in the dirt...
Brian Finster shavin' and smokin' a cigar?!?! |
#224
Did read thru whole tread again, had missed that some pic was a video. Realy liked those showing how your mill is working. Trying to learn as much as possible about this before deciding what to buy.
The bucket is impressive with all those extra parts. Looks from pic that you use aluminum EN755, is that the best for milling? Have found a local supplier where I live, hope that it´s possible to buy shorter pieces than 6m. Will do the shoes for keeping track right in alu. Looking forward to more milling videos! Dan |
#225
I attached the swing motor and the worm gear assembly
#226
I made some upper structure parts
#227
Nice work as usual Ari ! I haven't bee paying attention lately on your build. I refreshed my memory and looked back and see you did narrow the track pads. By the way; The plumbing on your cylinders is outstanding.
#228
Wow. It's been a while since I checked out this thread! Amazing progress and workmanship. It's a beautiful model already, even in a half completed state. Incredible. Some people just have greater brain power then others, I am sure. You are very talented!
Nathan |
#229
Great job so far Ari . ? , Did you use a spring type tube bender or something else ? I'm looking around for something .
#230
I use this Robbe made tube bender: http://www.hobbydirekt.de/product_in...ucts_id=159332
#231
that's a nice 1
#232
WOW Ari
When I look at your builds it is hard to believe, you do great work... Keep the photo's and information coming. WELL DONE ! ! greg |
#233
Been working on the counter weight, so many different corners...
#234
Here's how I made the side steps
#235
Nice steps. When cutting the bending lines, how deep do you go? 1/2 thickness?
Dan |
#236
Yes, about half way.
#237
I've been working on the upper body frame structure and now it's at the stage that I should start making the body panels
#238
The alu-master himself!
Looks amazing Ari!
#239
It's just amazing what you can build! Are you basing some of your dimensions off the smaller diecast mode, sitting next to the big model? I like how you make your steps. Maybe that is something I can try sometime. What kind of endmill do you use to cut the relief for the bends? Is it just a small square edged endmill?
Nathan |
#240
For the relief grooves I use this tool: http://www.cut-tools.de/cnc8fold-tool-p-3805.html I got some body panels done today ![]() ![]()
| Currently Active Users Viewing This Thread: 19 (0 members and 19 guests) | |
