#241
looks great
#242
To correct the issue, set the "on" side of the gear switch to 20 - 30%. Using mix, the pump will ramp up to the higher speeds with stick movement, and then will never go too slow with slight stick movement, saving your esc from much unnecessary heat build up.
#243
Thanks, Reg |
#244
The gear switch is two position switch, which is why said the "on" side set to 20 - 30%. If you want slower speeds with stick movement, turn your mix switch off (upper right corner of my radio).
I have my 850 on a DX18 now, but even when on the DX8 I had the pump on a 3pos switch & never used the 3rd pos anyway for highest speed, the mix would take care of that. And I set my throttle ch (boom lift) to always go full speed with/without mix within the programming b/c I need full power & flow to lift with any sort of speed... can't remember off the top of my head how I did that... but otherwise dig loose material with the mix off too conserve battery run time.
#245
Thanks Joe. I started to change things a bit this morning but I decided to leave it for another day. I did manage to try out the new digging bucket though. This pump motor set up makes such a horrible vibration at medium speeds. It really drives me crazy. I'm using a love joy coupling but I think I may make a solid sleeve to try. http://www.youtube.com/watch?v=lI3tP8vGCSQ http://www.youtube.com/watch?v=W-F53RRfqUA
I got a start on the clean up bucket today but didn't get a chance to finish it... ![]() ![]() ![]() ![]() ![]() Here's a picture of my 150amp torch. I normally use a #4 cup and change the tungsten to match the amperage as required. ![]() Reg |
#246
Thanks Reg
![]() What tungsten do you use with aluminium ?
#247
#248
Those new buckets look great !!!
Do you have any more pics of the slip ring you made??? (need some ideas for my shovel) KP |
#249
Had the toys out briefly yesterday to fill in a pothole on our driveway...
http://www.youtube.com/watch?v=drQIa...tJ-DusnO8Onw7A http://www.youtube.com/watch?v=HOC5-...tJ-DusnO8Onw7A |
#250
Hi Reg nice work on the buckets and your welds are getting better all the time. I hear that noise you pump makes on the video. I let mine run wide open just like a real one would unless they are doing some real tight work. I use 4S 6000 batteries and they run a long time. Joe ran my excavator at York Cabin Fever and ran it quit a while on 1 battery before I changed it. Keep up the good work. Ed
#251
whens the quick coupler coming reg :P
#252
I left one pile of dirt in the yard from my little S10 dump so that i could spread some of it out with the RC's. The weather finally turned really nice again yesterday so in the evening when I was tired of working in the shop I got the Volvo and the Euclid out for an hour or more of playtime. I haven't ran the excavator for quite a bit so i was definitely out of practice but at least everything worked!
https://www.youtube.com/watch?v=OBGt...tJ-DusnO8Onw7A https://www.youtube.com/watch?v=uM9e...tJ-DusnO8Onw7A https://www.youtube.com/watch?v=FPi2...tJ-DusnO8Onw7A Reg |
| Currently Active Users Viewing This Thread: 3 (0 members and 3 guests) | |
