ThanksTerry. i wish you guys were closer too! It's fun to run RC's but there's nothing like running as a group and the whole area comes to life
![]() Speaking of coming to life. I finally got around to building the second conveyor I need. Thanks again for the belt RW. It works great! This one went together real quick. Same set up as the last conveyor or as Reg calls it, the hippy conveyor. ![]() wooden beads and metal washers for rollers , 1/8 X 1" flat bar, 1/4" threaded rod for structure. Flanged bearings, bevel gears and motor from servo city as a drive and voila another Canadian red neck conveyor! ![]() ![]() ![]() ![]() ![]() And a video of it in action....... http://youtu.be/pXWA3WwS4WE |
Well, I got a chance to put some lipstick and makeup on the second conveyor. I'm real happy with the results and this will fit into my backyard perfectly. Nothing fancy but works.
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() And here is where the conveyor is going. Next I need to build a chute to direct the dirt onto the belt from the truck dumping platform. The angle in the pic is not right yet, too steep I think. ![]() ![]() |
I guess I shouldn't worry about the cosmetic stuff when I haven't even tested in the yard! Lucky for me it looks like first time out is a success and no major rework required so far. Final test will be dumping an actual load with the truck.
Here's test #1.... http://youtu.be/tXRz463KRNQ |
Currently Active Users Viewing This Thread: 7 (0 members and 7 guests) | |
